Hi @IC_8917824,
What is the product code that your are trying to use to access with Mathcad Prime 7.0 Ideally it should start with MX07
Did you updated your product code compatible with mathcad Prime 7 from e-store?
Vipul
Hi @IC_8917824,
Vipul
