Are these floating licenses or Node Locked licenses?
Floating licenses are in a pool of licenses on a server and anyone in your company can access them. The license management software will limit how many users may use the software at one time. The value is set when you purchase XX licenses.
A node locked license may also be installed on any computer in your company but may only be used on that computer. Multiple users may access the code on any one computer, one at a time. You will need to designate which company computers will be running MathCAD and then obtain licenses for each of these computers.
