MC 15 help window does not open
adar
7-Bedrock
It was working fine on Windows 10 but now I cannot see the Help file. I can see the help window at the bottom of the screen when I hover the mouse over Mathcad window but when I click on it, it does not open. Please help.
13 REPLIES 13
Have you tried pressing F1 key?
Cheers
Terry
Yes, I did. Doesn't work. When I hover the mouse on the Mathcad icon at the task bar, I do see the help window but it does not open.
amit
VladimirN
(To:adar)
Check this path: C:\Program Files (x86)\Mathcad\Mathcad 15\Resource Center\EN
adar
7-Bedrock
(To:VladimirN)
thanks! I got the guide pdf and for now, it is ok. I tried opening the quick sheet hbk as well. No luck.
May be I should reinstall the software.
Amit
VladimirN
(To:adar)
Also see the following articles:
adar
7-Bedrock
(To:VladimirN)
I clicked on this file inside the directory. But it doesn't run. I also have other hbk files. When I click on them, they too don't run. Till some time ago, they used to run very well. It appears to be happening after the latest windows update. I keep getting messages to update to Windows 11. Should I change over to Win 11?
amit
DJNewman
(To:adar)
Mathcad 15 was never certified for Windows 11; I wouldn't recommend it if you don't have to.
I manage the Creo and PTC Mathcad YouTube channels for PTC, as well as all PTC Mathcad marketing in general.
LucMeekes
(To:adar)
When you do see the help window associated with Mathcad 15 on the task bar, it is most probably open, but shown on another display (Do you have multiple displays set up?) or minimised to a few pixels.
Try the 'Task view' button:
that should also be on the task bar, to show all windows.
adar
7-Bedrock
(To:LucMeekes)
I checked. No, it is not there. However, I do see it in multiple windows but when clicked on, it doesn't show up. See attached screen shot.
amit
Hi Amit.
I notice the help widow shown in the screen shot has no content.
Check the following directory has html files.
C:\Program Files (x86)\Mathcad\Mathcad 15\doc\HELP_EN\Help
Cheers
Terry
thank you! At least I can find the information now.  Still waiting if someone can suggest a solution.
amit
When all else fails reinstall?  Look for any options to install offline help?
Cheers
Terry
?? How to install offline help?
amit
