I'm trying to find out what was changed or fixed in datecode 11.0.1.0 compared to 11.0.0.0. If there is a summary of changes/fixes on the website someplace, I haven't been able to find it. I support our company's users and would like to be able to tell them what is changed in 11.0.1.0 before they upgrade their installed version.
"Bug Fixes" and below shows no results.
Hi @PaulOrtmann and @ppal ,
Please do check the Update Advisor for the fix in Mathcad Prime date code 11.0.0.0 to 11.0.1.0
The issue of the result not being shown has been fixed.
Dhiraj
If you do a search "PTC UPDATE ADVISOR"
Clicking on it you get
I fail to see how this is of any use. There is no link that takes you to
There should be a link https://support.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
Hi @PaulOrtmann,
You can refer to this Knowledge article:
Note: (We are aware that the list of SPR fixed from Mathcad Prime Date code 11.0.0.0 to 11.0.1.0 are not shown and PTC team is working to fix it)
Dhiraj
Dhiraj rakho !
PTC Technical Support Note:
In addition to reviewing the Update Advisor lists generated instantly, please note the following:
For instance:
Please refer to the PTC support articles, which are continuously updated:
