You can install Prime Express 7 version (simultaneously) to understand if this is a problem with Prime 5 version or is it a system issue of the OS.
1. What version of Mathcad and Windows OS are you using?
2. What PDF printers are installed in your operating system? Try to add this free printer (CutePDF) and print through it: https://www.cutepdf.com/Products/CutePDF/writer.asp
Hello first of all thank you for your quick respone.
I am using mathcad Prime 5.0 and i tried pdf24 and the default windows printer.
The thing is that I allready used pdf24 for printing out my documents but suddenly it stoped working and also the option to save the document as a pdf dissaprad.
Try reinstalling this printer.
I allready did that twice and unfortunaly it dint work. It is also strange that the pdf printer works in every other programm i tried,
Can you provide a screenshot of the error and a log file?
Try this solution - "Error "An Unhandled exception occurred on the dispatcher thread"": https://community.ptc.com/t5/PTC-Mathcad-Installation/Error-quot-An-Unhandled-exception-occurred-on-the-dispatcher/td-p/706410
Unfortunaly that dindt work either
And you installed it earlier - "Mathcad PDSi Viewable support"?
Yes i got it installed
I will repeat here what I wrote earlier:
1. What version of Windows OS are you using (and what components of .NET Framework are installed )?
2. Try to add this another one free printer (CutePDF) and print through it: https://www.cutepdf.com/Products/CutePDF/writer.asp
I allready tried the CutePDF and it dint work either.
I am using Windows 10 and the 4.8 .net Frame Work is installed
Could you check if all the updates have been installed for Windows 10 and for the .NET Framework components at the moment?
Yes I checked that and everything is up to date.
Hello and sorry for my late respone i downloaded the express version and it worked to print a pdf from there
