Launch the License Wizard:
C:\Program Files\PTC\Mathcad Prime X.0.0.0 (where X.0.0.0 is your version number) and running LicenseWizard.exe.Choose "Activate purchased license": In the License Wizard, select the option that indicates you want to activate a purchased license.
Sign in to your PTC Account:
Enter your Product Code: You'll see a field to enter your product code (the "product key" you mentioned). This is typically a 22-character code you received when you purchased the software.
Acquire License: Follow the on-screen prompts to "Acquire License." The system will then generate and apply your license file.
Confirm and Launch: Once the process is complete, you should receive a confirmation that the license has been successfully installed. You can then exit the wizard and launch PTC Mathcad Prime.
Important Considerations:
Or Check here https://community.ptc.com/t5/Mathcad-Installation/All-About-Mathcad-Software-Installation/m-p/958630#M3807
Hi @SK_13604169,
Anurag
