The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Dear Luc- the repaired code is a flawless version of the 40 page original- and so much shorter in size than the corrupted file! Thank you so much. 😀
1.
Cause of "missing" log file:
Consider C:\ProgramData is a hidden folder.
Solution:
Ignore it and enter the specific path in an Windows Explorer (Shortkey: WindowsKey+E) window's path
OR change all Windows Explorer window's >View >Options >Folder and Search Options >View >Show hidden files and folders = enabled >Apply to Folders
2.
Cause of exception message:
Once the log file has been identified, one can open and read in a text editor program. All issues are stated there.
Note: Typically a "corrupted" Mathcad worksheet message does include empty ones (0 KB size) or worksheets with wrong file type suffix.
Correct is: mcdx, mctx
Solution:
No chance with a 0KB size file
OR: simply rename the file's suffix
OR: PTC customers file a new case to PTC technical support to try to fix that file:
https://www.ptc.com/en/support/case-logger
once the file is fixed it should be possible to retrieve in Mathcad Prime 8. But it won't get calculated without valid license.
"Is this possibly related to the fact that the core project was an existing Mathcad 2001 program I first converted to 8.0?"
No, not likely. Prime doesn't need excuses to corrupt worksheet files, it is known to do so at it own initiative.
In order for a repair attempt, the .log file isn't necessary, the corrupt(ed) worksheet file (.mcdx file) is required however. Attach it to this thread if you want someone to attempt a repair...
You forgot to attach...?
Or was the attachment refused? In that case, put the .mcdx file in a .zip archive and attach that.
Assuming you're using the online forum, the form to place any content looks like this:
OK, I think this will work. Never used a forum before!
Check if this works for you.
