After picking this option
an information appeared that test version had already been used, but thanks to your reply I realized just now that it's not necessary to choose and press "Next" in this window. Pressing "Exit" leaves Mathcad in Express version, and it is indeed installed on my PC now. Thank you!
Hi
Just get a new file using another email address to get a new down load. Run the install. If it recognise the machine as having used the trial it will go to express else you get another free trial which will revert to express as it times out.
From https://support.alfasoft.com/hc/en-us/articles/9727655437597-Installing-PTC-Mathcad-Prime-9-0
Thank you for your reply, but this is precisely the solution I want to avoid (having many unnecessary accounts 😀)
Are you saying it doesn't want to install (gives an error message and quits, or something like that)?
I should think you can install Prime, no matter what type of installation it is. As long as you do not apply for a license ( either a full license or a trial license) the program should work, in Express mode.
