Most of your points have been raised before, and many of them long, long ago.
If you are licensed, check here https://community.ptc.com/t5/Mathcad-Ideas/idb-p/PTCMathcadIdeas if the ideas are listed. Note that there is no guarantee the idea will be implemented any time soon, or at all.
Specifically:
3. You can open two instances of Prime at the same time, each showing a single worksheet at a time.
5. There is an extensive help, with many examples. And for those addicted to video's, check youtube.
6. , created by copying an existing math element and pasting it in the text box.
Specifically:
You can add any math expression in a text box or block by using "ctrl m" that is while holding down the control key type the letter "m".
