I have MathCAD PTC 7.0.0.0 (already installed)
I have a license file (already generated)
How do I connect MathCAD to that license file?
Other software that I use usually has some type of built in license management - so, in those scenarios, you open the application and then point that application to that license file.
Please respond
Browse your license file on "PTC Mathcad Options" window (tab "License"): https://community.ptc.com/t5/Mathcad-Installation/How-to-Acquire-Mathcad-Prime-30-days-License-for-Mathcad-Prime/m-p/706367#M15
Hi DS_10024912,
We have opened a PTC technical support case for your issue.
An engineer will call you and assist you shortly.
Anurag
Okay, thanks.
That worked. Thank you.
You're welcome.
