I recommend you to open a new "Case", here:
1. What version of the program are you using?
2. Read the following articles:
I am using the latest version prime 8.0.0.0. Every time, I try to put in values or text, the error message appears. I already checked if there was an issue related to net. framework, name of the document, clearing temporary files etc.
