There is no such file conversion, you will have to retype the contents of the file again.
What about it?
You can convert a Mathcad (1 through 15) .mcd or .xmcd file to Prime format (.mcdx file), using Prime7 or Prime 8.
PTC provides no tool for conversion the other way:
- Not from Prime to Mathcad.
- Not from Prime N to Prime N-x (with x=1..N-1).
