file install fail
BM_11023427
2-Explorer
file install fail
Installation issue: file installs self cancel and return a failure message. My PC is an Intel x15 with ample storage space for the application.
7 REPLIES 7
1. What version of the program are you trying to install?
2. What error message did you see on your screen?
Trying to install latest version only just downloaded and was failing at 1% install. Ive tried installing by going through the roaming files and that hasnt worked
See solutions from this article - "Mathcad Prime installer fails with status "Unsuccessful"": https://www.ptc.com/en/support/article/cs200121
Hi there, ive previously worked through these fixes and none have worked
LucMeekes
(To:BM_11023427)
I'm afraid you're at the mercy of PTC support (which this forum is NOT) to help you out.
You may want to open a support Case here - "Open a Support Case": https://support.ptc.com/apps/cs_loggers/case_logger/auth/ssl/log
