mcxd file downgrade
IB_14357483
mcxd file downgrade
Need installation file for Mathcad Prime 10. I have version 11 but I need to share files with a client that is using version 10.
3 REPLIES 3
LucMeekes
(To:IB_14357483)
I hope your Prime 11 license allows you to use Prime 10 licensed as well.
Following the download, you have to first uninstall Prime 11, then install Prime 10, then re-install Prime 11.
Prime versions can be installed on the same machine, but only in upward version number sequence. So if you expect to get customers with Prime 9, 8 and/or 7, then get those installation sources also and install them, starting at the lowest version number. You can skip versions...
Ah, I see there's more to this here: https://community.ptc.com/t5/Mathcad-Installation/Why-can-t-I-select-a-specific-version-of-Mathcad-to-download/m-p/1042529#M5033
Hello @IB_14357483
It looks like you have some responses from some community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
