You should first read and understand this: https://community.ptc.com/t5/Mathcad-Tips/Official-PTC-Mathcad-15-and-Prime-1-6-End-of-Sale-Announcement/ta-p/818870
Then you know that all versions of Mathcad and Prime are no longer supported. The installation sources are no longer available for download so unless you have CD's or other source files for installation, installation is going to be a challenge.
I recently read that someone copied over the entire Mathcad 15 directory and the license file to another PC and had it running, so you could try that.
If you succeed in getting the programs to run, but not licensed, you should try the license transfer. Info is here: https://community.ptc.com/t5/Mathcad-Installation/How-to-Transfer-Mathcad-license-from-an-existing-Host-ID-to-a/m-p/788323#M1599
Hi
did you manage to progress with this.
Im upgrading machines to win 11 and trying to re-install prime 3.0 on those machines with a new correct licence file.
Installs but cant apply licence.
Machines with Mathcad already on when upgraded to 11 work fine.
Any feedback welcome. We have perpetual licence.
