Let’s face it, planetary gears are cool. They are used in all kinds of mechanisms, including transmissions, motors, and turbines. Your challenge, should you choose to accept it, is to use Mathcad to build a worksheet that calculates the gear ratios and output speeds of a planetary gear under different configurations.
The math behind the gear ratios is straightforward. But users should be able to select:
How can the user select the desired component? How can you add intelligence to the worksheet to prevent an incorrect combination of input, output, and stationary?
What inputs do you want for your calculator? You will have to make some choices. Your choices could include:
Tools that you might consider include Combo boxes, programs, and functions involving strings.
Here are some technical references to get you started:
Once again, this is a great project for students to work on in teams. Make the worksheet as simple or as complicated as you want. Others can build on your work, and you can build on others. Let’s see what the community can create! Good luck!
Okay, let's get cracking.
I've included a solution, but I'm not entirely happy with the document structure or the elegance of the solution. Especially the configuration structure I'm not really fond of.
If a better way of working is found, I'm very interested to learn about it.
Cheers!
Bert Beirinckx
Wow, Bert, you put a lot of thought into this. I'm going to take some time digesting this but you clearly put a lot of thought into this. Thanks!
Community, what do you think about Bert's solution? Kudos to him for being the first. Does anyone think they can build on this?
bump as a reminder that March is ending pretty soon.
Unfortunately I am working in Mathcad Prime 7, the company hasn't upgraded to the latest version yet. May I ask to also provide a PDF?
Kind regards,
BBE
Gosh, maybe I should make an earlier deadline...!
But nice-looking work.
No problem. 😛
With that, thank you to everyone who participated and shared knowledge.
Dave will look through these all in detail and we'll have a follow up a little later this April. Cheers!
Edit: Orrrr very early May.
Sorry for the delay on the blog write-up and getting it published, but here it is:
https://www.mathcad.com/en/blogs/community-challenge-planetary-gears
@terryhendicott @adhariya @BertBeirinckx are all featured with your solutions. A lot of great techniques to learn from y'all!
And you have all received your badges for participating. Thank you so much!
