3D Response Surface
rgordon
3D Response Surface
I have a series of lookup tables that I would like to convert into a 3D response surface so that I can determine output values at intermediate input values rather than just assume linear interpolation. Can anyone help point me in the right direction?
13 REPLIES 13
RogerYeh
(To:rgordon)
VladimirN
(To:RogerYeh)
Hi Roger,
"Mathcad Prime 2.0 Help Center" now is available on the Internet?
http://www.ptc.com/cs/help/mathcad_hc/prime2_hc/index.jspx
RogerYeh
(To:VladimirN)
Yes, sir! And if it helps any, I noticed that the pages load faster in IE.
VladimirN
(To:RogerYeh)
Thanks!
VladimirN
(To:RogerYeh)
Hi Roger,
Are there any plans for Prime 3.0 release (available online "Mathcad Prime 3.0 Help Center")?
RogerYeh
(To:VladimirN)
Yes! Our documentation will be working on it next week.
VladimirN
(To:RogerYeh)
Thank you, Roger.
RogerYeh
(To:VladimirN)
VladimirN
(To:RogerYeh)
Great!
RogerYeh
(To:rgordon)
RichardJ
(To:rgordon)
If linear interpolation isn't good enough you could try spline interpolation instead.
tdevaraj
(To:rgordon)
This example is straight out of the help in Data analysis handbook
Hope this helps.
Thomas
See please here one real and typical example http://communities.ptc.com/docs/DOC-4335
