This file is a basic statistical analysis of daily flow data (18000 values) I did several years ago as part of a potable water source investigation.
I replaced the earlier live version with a pdf version because I could not figure out how to load the data set and have the Mathcad file read it on this site
Dixie,
I opened your file (in Mathcad 15 M010) and that's what I have:
Could you please check it?
I did not (and don't know how to) load the data set so it will work. I replaced the Mathcad file with a pdf version
Put a data table in mathcad (insert/data/table.) give it a name (data). Copy the data in the excel file, select the first cell in the data table, right-click and "paste table" from the pop-up menu.
The data is now resident in the mathcad file, can't be lost, can be posted.
One "full" question.
Is one connection between Mathcad and Statistica?!
Do not understand the question
Sorry,
it is (18000 points ?) one task for Statistica!
Or...
Still not following you Valery. What I meant to say is there are 18000 values in the data being operated on, better ?
I think it is a task not (only) mathcad.
