Analysis of Daily Flow Data (18000 values)
Joeboy
This file is a basic statistical analysis of daily flow data (18000 values) I did several years ago as part of a potable water source investigation.
I replaced the earlier live version with a pdf version because I could not figure out how to load the data set and have the Mathcad file read it on this site
8 REPLIES 8
VladimirN
24-Ruby II
(To:Joeboy)
Dixie,
I opened your file (in Mathcad 15 M010) and that's what I have:
Could you please check it?
Joeboy
(To:Joeboy)
I did not (and don't know how to) load the data set so it will work.  I replaced the Mathcad file with a pdf version
Fred_Kohlhepp
23-Emerald I
(To:Joeboy)
Put a data table in mathcad (insert/data/table.)  give it a name (data).  Copy the data in the excel file, select the first cell in the data table, right-click and "paste table" from the pop-up menu.
The data is now resident in the mathcad file, can't be lost, can be posted.
One "full" question.
Is one connection between Mathcad and Statistica?!
Joeboy
(To:Joeboy)
Do not understand the question
Sorry,
it is (18000 points ?) one task for Statistica!
Or...
Joeboy
(To:Joeboy)
Still not following you Valery.  What I meant to say is there are 18000 values in the data being operated on, better ?
I think it is a task not (only) mathcad.
