Automation Interface: Embedding a Mathcad sheet
ptc-4507537
7-Bedrock
hello,
how can I embed a Mathcad sheet in Visual Basic 2010 Express. I use Matchcad 14. In the Developper´s Reference there is indeed an example but I do not find Mathcad in the available references from the Project menu and I can' t find the OLE buttton. what am I doing wrong ??
In the VB projects folder ( in qsheet\samples\vbasic folder) in the Mathcad installation directory for working projects there are 3 examples of Mathcad's Automation Interface. I' am using Visual Studio (C#, Basic, C++ and Web Developer ) 2010 Express but I can't see the source code of the example "doughut" and "passvals". can someone tell me what program I should use ???
Thanks for your help
Oliver
Try to contact with PTC's technical support by creating a new "Case", here: http://www.ptc.com/appserver/cs/case/case_logger.jsp
thank VladimirN.
I will try to contact the PTC's technical support
You're welcome.
