BAR GRAPHS
Anousheh
BAR GRAPHS
Would anyone please look at the attached worksheet? At the end of this worksheet there is a bar graph that represent delta beta values and delta beta old values as bar graphs for 3 different numbers. As it can be seen, they are at top of each other. I would like to have these bars to be separated and plotted side by side.
I need your help.
Thank you
Anousheh
5 REPLIES 5
StuartBruff
(To:Anousheh)
Try adding 0.01 to the last 3 x-axis values ...
Stuart
Hello Stuart,
Thank you. This solved the problem. Is there any other way to overcome this?
Anousheh
PS Did you get my message few minutes ago? I found your name in two different formats! wich one is correct?
StuartBruff
(To:Anousheh)
Anousheh Rouzbehani wrote:
Hello Stuart,
I don't know ... that was just a quick look, quick fix, but I'm not entirely happy with it. If I get time later, I'll have a look at it in a bit more detail.
Yes, I did, thanks. Both are correct, I tend to use one for work-related matters and the other for personal stuff (which it mostly is).
Stuart
Thank you Stuart. Let's keep this discussion open until you get a chance to look at the issue in more detail.
Anousheh
Hello Stuart,
When you reply, how do you quote my writing?
I guess this is why I receive e-mail whenever you reply to my posts (which is very helpful).
Anousheh
