Hi...
I want to add some feature in model, so for that I am using pro toolkit programme. i decide the feature from mathcad programme.
e.g. I have one plate which is having 2 holes, but if i change any parameter in mathcad then my output will change and i decide that how many holes are needed on that plate from mathcad output. and i will add holes by using pro toolkit programme.
So is it possible or how can make relation in between mathcad and pro toolkit programme.
Prashant Pandarkar
Could you not write the answers to a format which pro toolkit is already compatible with?
Mike
