Better simplification
-MFra-
Hello everyone. There is someone who kindly can tell me what to do to get a better simplification?
(To:-MFra-)
You are symbolically evaluating an equation, not a math expression, and so the result can only be TRUE or FALSE, in Mathcad thats 1 or 0.
The rectangular command applies to the result of the whole calculation (0 or 1).
So if Q=1/3 is TRUE (1) we have  Re(1)+Im(1)*j=1+0j=1 -> that's TRUE
If Q=1/3 is FALSE (0) we have Re(0)+Im(0)*j=0+0j=0 -> that's FALSE.
So Mathcad is perfectly right - it gives you the truth value as commanded in rectangular form.
What you expected to see can be easily achieved by "assume, omega.0=real" or, if that applies, by "assume, ALL=real".
Sometimes a "simplify" or "simplify, max" is additionally needed and ever so often muPad refuses to give us the results we expect and need - bad luck.
Werner
6 REPLIES 6
AlanStevens
(To:-MFra-)
Don't ask me why!!
Alan
-MFra-
(To:AlanStevens)
Thanks for the tip!
If , however, I write the expression as in the figure, mathcad gives me an unwanted response. You can do something to get the correct solution?
Thank you very much again.
F. M.
-MFra-
(To:-MFra-)
Done! thanks anyway!
-MFra-
(To:-MFra-)
Thanks for the tip!
F. M.
(To:-MFra-)
Werner
-MFra-
(To:Werner_E)
Thank you very much. ...
The solution was so simple ...
trying again and again we'd all arrived ....
Greetings
F. M.
