Breakdown of formula
jkrulak
Hello everybody,
could you help me with this problem in MatCad 14: I do not know how is possible to breakdown formula.
For example:
a=5m
b=5m
(mathcad write formula like this ) A=a.b=25m2
I would be want to write formula like this, without manul write formula: A=a.b=5m.5m=25m2
Thank you
ViktorKorobov
(To:jkrulak)
Use symbolics command explicit:
Viktor
Viktor
19 REPLIES 19
ViktorKorobov
(To:jkrulak)
Viktor
Viktor
Thank you
Step-by-step:
http://twt.mpei.ac.ru/ochkov/Mathcad_14/Chapter1/1_018_All_Values_Step_by_Step.png
you are perfect man, thank you so much
Thanks!
But the explicit operator of Mathcad is not perfect (with unit for example) and we must sometime or all time do so
http://twt.mpei.ac.ru/ochkov/Mathcad_14/Chapter1rus/19.png
Hello Sir,
thank you for your help. I have ono question for you if you have time: please, how do you do finaly equal? When i press eaqual sign, It allways write the breakdown formula. I marked my problem in the picture. Thank you
Try please a sheet in attach!
I'm so sorry that I bother you but it is not working . Probably i have some settings wrong, i don´t know what´s wrong with my mathcad. I opened your mathcad and still same mystake. I made shotscreen of mathcad.
Probably you will be know what´s wrong. Thank you
Sorry, but you have old version of Mathcad 15 and must upgrade it
SEe too http://communities.ptc.com/message/190243
Hmm. I'm not so sure that's the problem. I only have M15 F000 installed and I get the following:
Alan
Alan
Sorry, I think Jan has Mathcad 14.
I have this problem with Mathcad Callculation Server 14.
The PTC company sold me MCS 14 per $ 15,000 and does not want to correct this error. And then the company generally refused to support those who bought MCS. Here is "a discreet service"!
Try please http://twt.mpei.ac.ru/MCS/Worksheets/test.xmcd
Ok. I didn't try it on M14.
Alan
Thank you for your help
You welcome!
But what version do you have - 14 or 15?
I had 14 but I just ordered mathcad 15 version. I hope it is gonna to be work.
Good luck - veľa šťastia - удачи!
i have next troubles with mathcad if you have time. I have three problems:
The first is: how i can change the unit in formula. It always change on predefined units.
The next problem is: how can i round the number in formula. It give me on 12 decimal point.
And the last is: when i have too long formula it write me to the edge. Is possible to follow fixed edge?
Thank you
Thank you
See http://communities.ptc.com/message/190243#190243
Thank you again
