Calculation
tmarkovinovic
3-Newcomer
Calculation
I want to calculate this expression for each i:
Is there anothe way to calculate expression for each i ?
Because now i is array and it should be real number.
Thank you.
Tomislav
Please attach your worksheet, its hard to impossible to debug a picture.
One idea: For the 6i you have to type 6*i, otherwise i would be interpreted as imaginary unit!
I suspect the problem is that you typed the lower limit as 6 times i. This makes Mathcad think i is the imaginary number, the square root of -1. Try typing the lower limit as i*6 (i.e. i times 6).
Alan
(To:AlanStevens)
Alan
I had the same suspection. But if he types 6 times i (with an explicit multiplication sign typed) it is not interpreted as imaginary unit. Thats the reason I suggested he should type 6*i (including the *) instead of just 6i.
AlanStevens
(To:Werner_E)
Werner Exinger wrote:
Alan
Yes, I should have read your reply more carefully!
Alan
