Can I define an expression as a single value?
kwadley
In the highlighted equation, I am attempting to define an expression with a single value.
Is this possible or should I first solve for 'Kg' as all other variable are defined?
Other tips on the best way to do this?
TIA,
Kevin
If you have all the other variables it should be relatively easy to solve for K.s.
You could put both equations into a solve block and solve that way.
Mike
LucMeekes
(To:kwadley)
You mean like this?
Yes, that's possible.
