Can I publish a Mathcad Prime File to Wordpress
ppal
18-Opal
Hi
Can someone help me with some pointers to achieve above.
Ideally - file can be dynamic  but will settle for a static file.
Sample file attached
ValeryOchkov
(To:ppal)
None of these links work
LucMeekes
(To:ppal)
One of these links works, namely the first one! There you can read that Mathsoft (the originator of Mathcad) once had the Mathcad Appolication Server (MAS), which allowed to show mathcad sheets on a web-page and actually  perform calculations with it. Unfortunately Mathsoft discontinued the product and since PTC took ownership no comparable functionality has been developed.
You should be able to use any Mathcad worksheet the same way as you can port them to MsWord: as a pcture.
