Can I use Polyroots in a in a loop ?
remslie
Hi, I am wishing to solve a Hertzian contact problem for sub-surface stresses for multiple points in order to plot contours. The solution routine uses Polyroots to extract the maximum root for use in the calculation and works fine for a single point. Is it possible to automate the process in a loop for variable x, y and z using Polyroots? I tried a couple of attempts but get errors.
Any assistance would be appreciated.
Thanks Ross
31 REPLIES 31
remslie
(To:-MFra-)
FM,
Thank you so much for your assistance in working on my problem. You have been very generous with your time and have earned a holiday!
Best Wishes
Ross
-MFra-
(To:remslie)
I regret to tell you, but if you are satisfied with the answers, and do not wait others, you should conclude marking an exact answer.
Thank you
With best regards
FM
