Can't run
SteenGroðe
6-Contributor
Can't run
Reports an error to M$ - my guess will be on something related to .Net UK/US that probably is different to .Net DK (I have repaired .Net to see if this made any difference)
Sorry I forgot this in the first place:
Windows XP SP3 DA (so this may indicate som international issue)
IBM X31 2GB RAM
And even more:
EventType : clr20r3 P1 : ptc.spirit.exe P2 : 1.0.3510.21024
P3 : 4a819f10 P4 : presentationframework P5 : 3.0.0.0 P6 : 4938d608
P7 : 625a P8 : e1 P9 : system.windows.markup.xamlparse
Steen Gro�e
7 REPLIES 7
Based on the known issues table, it might be to do with this point:
Currency symbols = Not yet working
http://www.ptc.com/products/mathcad/beta-test/known-issues.htm
Philip
___________________
Nobody can hear you scream in Euclidean space.
The currency symbols have just not been hooked up yet. That is a separate issue than whether Mathcad Prime 1.0 runs or not.
Mona
Hi all,
Also can't run the program, both on VISTA ULTIMATE Polish and XP Professional Polish.
Steen, I have a same message Smiley Happy (instead of P6):
EventType : clr20r3
P1 : ptc.spirit.exe
P2 : 1.0.3510.21024
P3 : 4a819f10
P5 : 3.0.0.0
P6 : 498d263f (Steen had: 4938d608)
P7 : 625a
P8 : e1
More systeminfo was sent directly to -'.
Jerzy Cierpicki
Steen,
Do you have .Net 3.5 SP1 for Danish? Are you unable to install Mathcad Prime 1.0?
Mona
SteenGroðe
6-Contributor
(To:mzeftel)
On 8/13/2009 4:34:22 PM, MonaZ wrote:
>Steen,
>Danish?
If we focus on the laptop in my lap at the moment I have dotnet 3.5 sp1 with a Danish language pack. As far as I can see the dotnet is the same for any language but then you can have more than one language attached.
Are you unable to
I have no issues with installing. But I can't run the program.
Steen Gro�e
Steen,
I have reported this and will let you know when we have an answer.
Mona
Mona,
Looks that program run is solved.
Simply program must be executed by eg.:
"c:\Program Files\Mathcad\Mathcad Prime 1.0 Beta\Ptc.Spirit.exe" en-US
for english language version.
But... there are some problems with national (polish) diactric letters.
For example if I click simultanously "Right Alt" + "a" (or "A") then normally it would generate polish letter "a" ("A") with a little "tail" but in Mathcad Prime it choose all the document contents (like typical "Ctrl" + "A").
Jerzy
