The unit of density is kilogram per cubic meter, which can be written as
kg/m^3
or
kg
__
m^3
MathCad uses the bottom method for display, is there any way to make it show how it is typed above? I ask because I prefer it like this asit looks neater.I saw no such options in the Worksheet Options.
is there any way to make it show how it is typed above?.
Not the easy way, but it's possible
One easy way ![]()
Tricky Valery! ![]()
it was one tip from the book "Tips for Mathcad users"
Valery,
Please link your site with Google Translate (item #2 for the plugin: http://support.google.com/translate/?hl=en#2534535 ) or other site translation plugin. ... my lord, you have some really good tricks up your sleeve.
I think we can use this solution:
There is no way to input the superscripts? I tried to do it with the superscripts, but it didn't work out for me. Though this does solve the problem.
You may use the small "3" (AltGr-3) as in my first post.
The superscript was exactly the reason why I was impressed by Valery's trick with the third root.
If you cannot do it, but really want to to do it, you can do it ![]()
