There is no placeholder for units in chart component The old plot had unit place holder for scaling the graph units This seems to be missing in MP 7
Also using the chart component in the input area they are not automatically Assigned units to x and y expression I cannot see Corresponding base units displayed which makes it even more difficult
What is the solution for this??
Use the built in (old) plotting facility. The new chart component is a badly integrated third-party add-on.
Or was there a specific reason for you to use that new component...?
Yes I can use the old plot however wanted to go through the chart component to check the functionality so it seems like a huge missing in the new graphing functionality
The 2D Chart Component does not support units.
The solution is to divide each of your expressions assigned to the X/Y pairs by the units that you want the values to be displayed. For example,
This is identical to how this was done in Legacy Mathcad.
