Combo Box with variables
KB_10612849
8-Gravel
hello.
I am trying to make a combo box with multi choices of various equations depending on defined variables, the attached file will explain it very well.
how can I make it work?
thanks,
 says that. Prime 7 sheet attached.
@KB_10612849 wrote:
hello.
thanks,
I hope https://www.youtube.com/watch?v=vMLCU3uXZmA video explains to you how to use ComboBox.
Martin Hanák
This PTC Mathcad Prime tutorial shows how to use the new Combo Box Input Control for changing the values of variables to pre-determined values from a list. For more information, visit https://www.creowindchill.com. If you learned something from this video, please give it a thumbs up. If you like ...
thank you, but unfortunately, I need to make equations inside the compo box.
you can define combo box for two values:
numerical_coefficient ... 0.75, 0.56 and so on
Kc ... 1, 1, 1.5, 1, 1
... and use this "combo box variables" in equation.
Martin Hanák
Thank you.
