ComboBox VBScript error
SteveMackey
I have recently updated my computer to a 64 bit Windows 7 platform. I am now getting an error while using MathCad 14.0 M020 on spread sheets that have worked previously using combo boxes. The error is "Microsoft VBScript runtime error Line16 Error0 Object required: 'ComboBox'". And when I try to insert a Component-Scriptable Object, the Microsoft Forms* selections are not even available as on option. During the initial install of MathCad 14 the .NET Framework prerequisites were not installed from the CD. I have manually installed the .NET Framework 3.5 and the Microsoft Report Viewer which includes the Microsoft Forms. I also upgraded my MSXML 4.0 SP2 to MSXML SP3. I then uninstalled and reinstalled MathCad 14 and am still getting the same error. Has anyone came across this before?
22 REPLIES 22
I haven't come across this before, but you try contacting the Mathcad License and Install team directly.
Mike
Hi Steve,
Im also encountering your problem, have you figured out the cause? Before i can also run the combo box but when i used windows 7 and mathcad15, its not working anymore. Thanks
What version of M15 have you got?
Mike
Hi Mike,
How to know the version of mathcad im using? Is It this? Mathcad 15.0 (M010 [MC15_M010_20110622])?
When i try to insert a combo box, i can place it on the worksheet but i cannot edit its script because when i right
click on it it says internal error
Thank you
That's wierd, but as Richard said there might be an issue with the 64 bit o[perating system. I have seen the problem a few times
Mike
I started experiencing problems with other programs and determined I had a registry error. I reformatted my machine, reinstalled the software and the problem went away.
RichardJ
(To:SteveMackey)
There seems to be two threads going on this subject:Object required:'Combobox1'
It looks to me as though the MSForms 2.0 controls, including the Conbobox, and not compatible with the 64 bit OS.
I think so too because i've tried with different laptops all with the same OS, windows7 64 bit still the error occurs. Do you have idea on how to fix it? Thank you very much
RichardJ
(To:ptc-4163643)
Do you have idea on how to fix it?\
No, sorry. I'm still using XP.
i already figured it out. It requires the full version of MS office in order for the combo box to load. I already installed the full version and was able to run the combobox already.
Cheers for coming back with a solution.
Was you trying the component on a machine without a full version of MS?
Mike
yes, all the laptops i tried only have a starter package for MS word and excel. i've been searching for this solution for a long time already hehe glad was able to pinpoint it. thanks everyone
What version MS Office means and what includes Full Package?
I have two 64 bit system with windows 10 , One of the m can opens all my files with combo box and the other shows up eroor : failed to lunch application ..
i have the same situation between two 64bit windows 7 system!
LucMeekes
(To:Ramakr56)
And did you check the installation(s) of MS Office on both PC's, as suggested higher up in this thread?
It seems that you require a full installation of MsOffice in order for the combo-boxes to load...
Thanks LucMeekes
Actually here in our office there are 4 station and all of them have the same office,
2 of them have no problem, 2 of them can not open mathCad files with combo boxes...
I have seen somewhere MS net framework and MSXML4 dll files also needs to be updated but I have not checked them accurately yet
I changed my MS office from 64bit to 32bitversion ( mathCad 15 is a 32bit application) and problem solved
LucMeekes
(To:Ramakr56)
Great!
Just Change your MS office from 64bit to 32bitversion ( mathCad 15 is a 32bit application)
Ramak
tlpeng-itdept
(To:SteveMackey)
We experienced this error after reverting back to Win10 from an accidental upgrade to Win11. I have seen some indication that 32bit VBA has been deprecated in Win11. Assuming that, Msoft in its great wisdom, did not feel it necessary to restore the removed 32bit VBA components when reverting back. Indeed, there was a message when reverting back that some apps would fail to work correctly.
The missing component is the 32bit version of "Microsoft Forms 2.0 Object Library" made up of 2 files: fm20.dll and fm20ENU.dll in \SysWOW64 (the 32bit system area - note that those same files in \System32 are the 64bit versions on 64bit Windows, which Mathcad15 cannot access, being a 32bit app). What proved to be quite difficult was how to reinstall the Library. There does not seem to be a download/installer for the Library. I was not able to determine how the Library was installed in Win10 originally. While 32bit Office definitely installs it, 32bit Office had never been on this PC - only 64bit Office. I'm not sure if Win10 came with it originally, or if some other 32bit app on the PC installed it. BTW, this is a strong indicator that Mathcad15 will not run on Win11 without some kind of manual intervention.
SOLUTION:
Find fm20.dll and fm20ENU.dll in the \SysWOW64 of another PC and copy them over to the same folder of the broken PC. Be sure to not mistakenly take the ones in the \System32 folder. Then register those 2 files by opening an Admin command prompt in the \SysWOW64 directory on the broken PC using the 32bit regsvr32 command (not the 64bit regserver command). Simply enter >regsvr32 fm20.dll, etc. NOTE: I would strongly caution against downloading these .dll's from 3rd party websites, as some sites suggest. Much safer to get them from one of your own, known trustworthy PCs.
Trivia: Ever wonder what the WOW means in \SysWOW64? Windows-On-Windows, meaning 32bit Windows running on top of 64bit Windows.
@tlpeng-itdept wrote:
SOLUTION:
The actions you have indicated are sufficient to perform only with the fm20.dll file, in addition, performing registration for the second file causes an error.
