Commas in subscript
ptc-5008217
Commas in subscript
I am trying to base my calculations around eurocodes which uses a lot of subscript notations to define things, including commas i.e. Nt,Rd where t,Rd should be subscript. However I can only seem to put one continous list of characters subscripted and no commas when defining a variable in Mathcad. Is there a way of doing this? (I am usimg Mathcad Prime 2.0)
Thanks in advance,
Rob
Thanks in advance,
Rob
Try this please in Prime 2
A space we cannot so insert a variable name
17 REPLIES 17
(To:ptc-5008217)
It would be possible in Mathcad 15 and below to create that kind of variable names (using Ctrl-Shift-K)
But Prime is much more limited. As far as I know there is no way to create such names in Prime.
Ctrl-Shift-K feature has been added to M' 3.
Mike
Mike
Good to know.
Another way of doing it in Prime would be using the matrix index - nevertheless i wouldn't recommend doing so.
Define t and rd to be zero (maybe in a collapsible area) and create N as a 1x1 matrix:
Neat workaround, but could get a little confusing
Mike
Mike
Yes, thats why I said that I really would not recommend doing so. Especially as I suspect that most of the times a sheet would need t and rd to be special values or ranges, so you would have to resort to differently labeled variables ... better wait for P3 and use the good old Ctrl-Shift-K trick (which itself can be confusing enough, though).
Agree.
Mike
Thanks in advance,
Rob
Thanks! I wasn't aware of that possibility. Works like a charm!
And you are right, neither [space] nor Alt-2-5-5 will have any effect.
You welcome!
"There are more things in heaven and earth, Horatio,
Than are dreamt of in your philosophy."
It was a rule in the Soviet era - do not get used to Delicatessen - soon it will become scarce
This trick not work in Mathcad Prime 3 with an inserting Math area into Text area.
But we can create kJ/(kg K) etc in Prime 2 and use in Prime 3 and... new tricks
So its a trick with an expiration date in a few months!? 😞
But as Mike posted we will be able to use something like the Ctrl-Shift-K method in P3 again.
We will solve the problems as soon as they arrive!
No
Valery I'm sure it has been added.
Mike
Mike
Show please you hope here Mathcad Prime 3.0 Discussion
Valery you are correct. I am mistaken for the Ctrl+G keyboard shortcut. My mistake.
Mike
Sorry Werner I got it wrong. It was the Cril+G keyboard shortcut.
Mike
Thanks for your help, works a treat.
