Composite array does not show all elements
WP_10666306
2-Explorer
I create a composite array, but the result does not show all the rows. It is like it had a limit for the row's large that can be shown as a result.  I tried to expand it, but it does not work. How can I solve it?
LucMeekes
(To:WP_10666306)
Move your mouse to the three dots in the array display (see red arrow)
You will get a grey bar, and the pointer changes shape.
Then you can drag that end of the array up or down.
6 REPLIES 6
LucMeekes
(To:WP_10666306)
Hello Luc, Thanks for four answer.
I did all that you indicate in your answer.  But, for some reason, it does not work in my case. I appreciate if you can send to me the file with your solution.
You must do all colums to expand.
Attached the result sheet.
Hello ttokoro:
I'm sorry, I cannot open the file, it is in other version of mine. I have Prime 8. May be you can hang a video with the solution.
Thanks.
Thanks for your answers. It worked after I restarted my PC. I think it was a problem with the memory, I noticed that Mathcad becomes slow sometimes.
