Composite array does not show all elements
  • May 30, 2023
  • 1915 views
I create a composite array, but the result does not show all the rows. It is like it had a limit for the row's large that can be shown as a result.  I tried to expand it, but it does not work. How can I solve it?
Best answer by LucMeekes
Move your mouse to the three dots in the array display (see red arrow)
You will get a grey bar, and the pointer changes shape.
Then you can drag that end of the array up or down.
LucMeekes23-Emerald IVAnswer
Hello Luc, Thanks for four answer.
I did all that you indicate in your answer.  But, for some reason, it does not work in my case. I appreciate if you can send to me the file with your solution.
