I face some issues in reading, understanding and working with a Mathcad sheet which comes along with some programs. The programs used is having some errors it seems.
It would be better if some one debugs it.
Dhinesh
Dhinesh wrote:
Alan,
Yes, but still I can see some errors.
The continue syntax is still having some issue it seems.
Dhinesh
I didn't scroll far enough down the worksheet to see the other errors!
Continue and Return don't work because they've been typed by hand. They must be selected from the programming menu in order to work. Now fixed - see attached.
There is an error remaining. Function wca3 won't work because it calls function vt. Function vt is not defined anywhere in the worksheet!
Alan
Alan,
Dhinesh
Dhinesh wrote:
Alan,
Dhinesh
Alan
Also, in the document there are a lot of undefined functions and variables which are located below function "wca3 (F,x,y,z)".
