Converting 2D Circles into 3D Cylinders
ross52
I need to convert the attached "top view" of a cylinder in to a 3D representation. Each color is a different layer of the cylinder and each layer is solid (for example, the green would extend all the way to the blue and the blue to the gray, and the middle is solid gray). I don't know the length of the cyliner yet, so any made up value would work.
VladimirN
(To:ross52)
Hello!
Maybe this will help: http://communities.ptc.com/thread/35155
P.S. I have also attached a file to a message (but there are hollow cylinders).
