OK, here you are:
fraction3 was the first attempt and only works with two column matrices while fraction4 should work with both.
Again no errorhandling - use at your own risk 😉
See attached worksheet.
WR
fraction is sort of a modifier for confrac and I don't think that there is a built in function which does what you want. But it's not hard to write your own - see attached file.
WR
Many thanks for the following function, Winfrod.
-LL-
If you don't mind, could I go beyond my question a bit, Winfrod :
Best Regards,
-LL-
Not sure what you really need. Does the problem you are working on involve continued fractions of numbers or of functions? As you have determined yourself my fraction2 only works with a single column vector as is the result if you apply confrac to a number. Its a quick hack and furthermore has no error handling whatsoever. So e.g. the last number in the vector must no be zero or the product of the last two numbers in the vector should not equal to -1.
My fraction2 does not work with those two column matrices as are created when you apply confrac to a function or confrac,matrix to a number.
What did you expected to get by applying funtion2 to the result of e(x) confrac? You sure can not excpect to get the function e(x) but rather a rational function approximating e(x) to some degree.
If you need a function dealing with those two column matrices the function has to be rewritten.
Let me know what you need.
WR
Hello again,
My original question was answered. I have a related question:
Best Regards,
Loi Le.
OK, here you are:
WR
I greatly appreciate your help, Winfrod :
-LL-
