I typically do all my work in a textbox and recently I cannot copy equations and text together and paste below inside the textbox. I would do this all the time but now it doesn't work. I can copy from a textbox and paste outside the text box, but this is inconvenient.
Anyone have any insight into why this may be happening now?
Thanks.
The previous post had indicated that PTC were aware of the issue and would have it fixed in MathCAD Prime 9.
PTC haven't fixed it.
I wouldn't expect software this expensive (for those that have paid-for licenses) to need OS patches to make it work properly.
according to https://www.ptc.com/en/support/article/CS384330 the fix is planned in Mathcad Prime 10.0.0.0 (in March 2024 ?).
To confirm this information I suggest you to open case at PTC Support.
Thank you! It works!
(It's strange, but it didn't work out the first time - I ran scripts, installed updates, but it worked only after the second register edit)
Not working for me now.
I had my M Prime 8 and 9 working using the workaround suggested but in M Prime 10 it stopped working (with or without workaround)
After sharing this issue with PTC support, I have to clarify that the problem is not something that was working in version 9 and not working in version 10.
