Copy & Paste to Word Document
lsingh-2
7-Bedrock
Hi All,
Does MathCAD Prime 3 support copy and paste to a Word file? Prime 2 did not support this.
Regadrs,
LS
17 REPLIES 17
(To:lsingh-2)
Yes, but unfortunately only bitmaps, no reasonable vector format. So its not really useful.
Werner,
That means it is the same as it was with MCAD 15?
(To:lsingh-2)
NO! Mathcad 15 was NOT bitmap,
See attached a Wordfile showing the difference. try to resize, etc.
Hi Werner,
How did you make the last copy from prime 3.0 ? I tried a Ctrl+C in prime 3.0 but I cannot paste it in word.
(To:ptc-3982555)
I used standard Ctrl-C / Ctrl-V.
The difference is HOW you highlight the expression before you press Ctrl-C. It has to be pale blue. like when you are about to move or delete the region, not pale gray.
In other words - you have to highlight the region, not just the expression.
Thank you for your reply. That's what I used to do. But now I noticed that if I copy/paste only one block, it works, but if I try to copy paste several blocks, it does not work. This makes no sense. I will not copy every block of the whole page, it will take a while in reordering and if I make a change, I will have to do all the work again.
(To:ptc-3982555)
Obviously a severe limitation of the copy functionality in Prime 3.
If a single region is highlighted, ctrl-C copies a bitmap (not a vector graphic metafile, and thats a shame anyway) to the clipboard.
If more regions are highlighted, nothing seems to be copied to the clipboard. At least Word shows an empty clipboard.
Its beyond my understanding why a company with a high end CAD software as its main product is not able to implement a useable (and that means not bitmap) cut and paste functionality.
We can copy Prime's remarks into Word as text.
Valery,
How about copying integration, theta, etc. symbols into Word? I am more interested in copying "exactly" from MCAD Prime to Word.
Its ok, even if I am not able to edit in Word, I want to make sure that I can copy exactly.
LS
Try do this with/thru pdf-format
Thanks Werner. The copy and paste from Prime 3 is not clear and blurry, whereas MCAD 15 is very clear. So no proper improvement in MCAD Prime 3 then. I guess I will stick to MCAD 15. Thanks Valery.
Have you tried doing "Paste Special" from Word?
Actually the paste feature is not available in Word in this case. I tried with Word 2007 and 2010, and windows vista and 7.
With MC 15, word 2007 or 2010, it works.
With MC Prime 1,2,3 I don't know
(To:gfraulini)
Unfortunately there are a lot of things which work in Mathcad but don't in Prime.
(To:gfraulini)
You are takling about copying from Word to Mathcad (and there is no "paste Special" in Prime), but Sébastian is doing it the other way round, Prime-->Word.
I talk as MC15 user, and it works in both modes.
I learn now that there isn't the "paste special" in prime...bad thing...
