Aug 28, 2024 7:23 AM UTC
Copying Mathcad Prime equation into Word or Powerpoint equation, and vice versa
Hi all
Does anyone know if there is a way to paste a Mathcad Prime equation into an native equation in Microsoft Word or Powerpoint? And also the other way around, from Powerpoint into Mathcad Prime?
Thanks!
18-Opal
Sep 25, 2024 4:06 AM UTC
Take (:= (@FUNCTION (@LABEL VARIABLE f) (@ARGS (@LABEL VARIABLE x))) (/ (+ (^ x 2) (@APPLY sin (@ARGS x))) (@APPLY ln (@ARGS x)))) and ask CHAT GPT to convert to LaTex. Then use equation function in word.  Follow https://youtu.be/QK5extaCbaI?si=J2nL1LEeF_27KRde
Probably ok for small batches.
Aug 28, 2024 8:38 AM UTC
@PEAH wrote:
Hi all
I fear, no, as neither software provides an import/export facility for the proprietary equation format of the other, nor does Prime in any way support the export in any open equation format.
If you copy a math expression (not the full region) like
from Prime to a text editor, you will see this
The equation editor of M$ Office can't handle this.
PEAH12-AmethystAuthor
Aug 29, 2024 7:20 AM UTC
Hi Werner
Thanks for your reply. Just because Microsoft's equation can export as MathML. And Mathcad Prime sheets are saved as set of XML files. But you are probably right that there is no straightfoward solution.
Community Moderator
Sep 4, 2024 4:27 AM UTC
Hello PEAH,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
18-Opal
Oct 1, 2024 9:05 AM UTC
Hi ppal, thanks, that's a good suggestion.
