DE Laplace solvers
ptc-1368288
DE Laplace solvers
In separate sheets for easier qs style and especially for "clear var" that 14 users have reported being a problem. Try these three sheets and report to Mona if working or not. That will help the PTC team about the InvLaplace reported incorrect as per the books .
Interesting to see if it works in 14.
jmG
Mathcad 14 needs a little help to do the inverse laplace part here.
stv
>here.
>stv
___________________________________
Thanks for making it work for 14 users. The 14 Laplace algebra and the construct around a dummy [L, solve(L)] is hard to visualize. I can see it comes from an unterminated piece of work from books. The question is about all the traditional feedback and control Laplace applications, i.e: how it handles the Laplace algebra ? It you are interested and willing, I will pass something on that.
Jean
>visualize.
>Jean
nL-Y0m+msL = �(s) is just the Laplace transform of your equation nf(t)+mdf(t)/dt = q(t), where I've simply used L to represent the Laplace transform of f(t). The solve statement then solves for L.
I guess I could have written the solution directly, as you did in your original.
Not sure if this addresses your point or not!
stv
>>visualize.
>>Jean
>then solves for L.
>original.
>not!
>stv
I understand, but my logical understanding is getting more square with the years. Still, Mathcad 14 rejects my beautiful 11.2a solver, as you said. BTW, what about the 2nd order homogeneous ?
Jean
