Hello everyone.
I wonder if it is possible to put a series of calculations as a function of two variables, to avoid typing the same operations for each case.
Attached is a spreadsheet with what I intend to do
Thanks in advance
We can do linear or spline interpolation!
Give us this table and we will do it!
Is the attached going the way that you want?
Regards
Andy
Thanks Andy, but there is a way to "idx" may also be used to generate vectors "t" and "Q"?
when I try, I get this
It is perfect. Thank you very much to all.
