Dependet variable
BPP
8-Gravel
8-Gravel
Dependet variable
Hello everyone.
I wonder if it is possible to put a series of calculations as a function of two variables, to avoid typing the same operations for each case.
Attached is a spreadsheet with what I intend to do
Thanks in advance
(To:BPP)
Hope the attached sheet helps.
ValeryOchkov
(To:BPP)
We can do linear or spline interpolation!
Give us this table and we will do it!
AndyWesterman
(To:BPP)
Is the attached going the way that you want?
Andy
Thanks Andy, but there is a way to "idx" may also be used to generate vectors "t" and "Q"?
when I try, I get this
(To:BPP)
BPP
8-Gravel
8-Gravel
(To:BPP)
It is perfect. Thank you very much to all.
