Different combo boxes depending on parameter
DM_10127316
I have three materials. Each with their own sub types
Material - Type
A             - A1, A2, A3, A4
B             - B1, B2, B3, B4
C             - C1, C2
My idea is to let the user to select the material and type. I was thinking on having a combo box to select a material and then a second combo box that would change depending on the material selected.
I have been trying for quite a bit without luck. Maybe there is an alternative way of doing this? Any help is appreciated!
LucMeekes
(To:ttokoro)
Ttokoro's file translated to Prime 7.
LucMeekes
(To:DM_10127316)
(Real) Mathcad, or Prime, and if Prime: What version?
Forgot to mention it, sorry!
Mathcad Prime 7
Combo box with EXCEL can select what you want from EXCEL sheet data in Mathcad. Prime 8 sheet attached.
LucMeekes
(To:ttokoro)
I recommend upgrading to Prime 8 for slightly better capabilities in combo boxes.
Did you know you can add columns to your combo box? Doing so creates a vector of data in the same order.
e.g.
v
