How to add a digital BPF (FIR/IIR) to the sampled data?
Consult the Help system of Mathcad, I'm sure there are some nice examples.
But they may be in an e-book called 'signal processing', which should also be accessible through the 'Help' menu..
The front end of a real DSP must be made up of a low pass filter, for example a Butterworth LP of the fourth order, followed by the sample and hold system and then by the ADC. The sampling rate must comply with the Shannon sampling theorem (don't take a sample rate at your leisure).
How about FIR filter?
You could be interested in this: https://community.ptc.com/t5/PTC-Mathcad/1-DIGITAL-FILTERS-EQUIVALENT-TO-LINEAR-CLASSICS-BASICS-xmcd/m-p/449023#M176356
