Jean,
I have just fell across this useful function.
Can you explain how this works and how the Matrix "M" is generated.
Mike
Pallete Matrix + Button Picture
Pallete Matrix???
How was the picture first created? Could this be used on graph extracted from books/standards?
Mike
>Palette Matrix???
Sorry - Vector & Matrix toolbar!
By scanting a book, e.g.
>Palette Matrix???
Valery,
I have just tried to replicate a graph I saved from the net, see attached worksheet.
As you can see the Mathcad graph looks nothing like the image, any suggestions?
Mike
Cheers Valery,
What software have you used to extract the graphed area? In the worksheet you refer to "A spy quick trace extractor"
Mike
Message was edited by: MIke Armstrong
MIke Armstrong wrote:
Jean,
Mike
Mike,
The matrix M is created from the "Matrix clipboard operation". An essential procedure in image processing. If you don't have the twist, please let me know. There are several tools to digitize a graph. I use "Tracer" from Markus Karolweski, there is also the "Mathsoft Digitize". For very difficult cases, I use my own. In most applications, it is necessary to clean in Paint. The quality of digitizing depends upon the quality of the image. Too much distortion ==> recycle bin.
Jean
Mike, The matrix M is created from the "Matrix clipboard operation". An essential procedure in image processing. If you don't have the twist, please let me know. There are several tools to digitize a graph. I use "Tracer" from Markus Karolweski, there is also the "Mathsoft Digitize". For very difficult cases, I use my own. In most applications, it is necessary to clean in Paint. The quality of digitizing depends upon the quality of the image. Too much distortion ==> recycle bin.
Jean
Thanks Jean,
I have just downloaded a copy of Tracer from a link from yourself from a previous thread.
Have you extrapolated the points using Tracer?
Mike
Thanks Jean,
Mike
_________________________
Sorry Mike, I don't understand "extrapolate" in term of digitize ?
Jean
Jean,
You managed to clean the graph and show the top section of the curve. I thought you had extrapolated to get those values - my mistake sorry.
Have you any tips on how to use the tracer software - Do you remove the grid lines using paint or tracer?
Mike
Just went through that this morning.
> binarized
> edit in paint to remove interferences in the graph
> select the region to digitize
TTFN
> binarized
TTFN
Eden,
What does binarized mean?
So the curve gets selected and passed to the digitizing software?
It seems that the trace software can take the image or the extract the numerical data to Excel.
Mike
Some of the curves I get are jpegs, which may have pretty ratty contrast to the background, so I generally try to grayscale the graph, and if its contrast is OK, I convert to a two-value color format, and then convert back, but I'm not sure whether Tracer will do two-value.
In any case, you get a graph with only black or white values. Then, in Paint, I eliminate most of the graph borders, leaving just enough to digitize the corners of the graph for proper scaling of the data. Then, you just drag/select the region to be digitized, and hit "Automatic" and it does its thing.
I only use Trace about once every 3 or 4 yrs, so it's always a learning experience when I use it, but I'm usually pressed for time, as well. There's probably better ways to do, but I'm loathe to try and figure them out, since I'll probably have forgotten them the next time I use the program.
TTFN
Cheers for the advice Eden,
Much appreciated.
Mike
Jean,
Mike
How I digitize :
1. sufficiently clean graph ==> Valery
2. zoned image-graph ==> Mathsoft digitizer
3. more ambiguous graphs ==> Tracer
4. RGB, Gray and any unfeasible graph ==> Hyper-Digitize [jmG]
5. specific value or "range value" ==> Mathcad EXTRACT(,,,) ... extract(,,,)
The Hyper-Digitize is manual only, works on the "mouse numeric pad".
APPEND to file. For images, a great lot of images processing can be
applied to help extract. Nothing special about using Tracer. Some web plot
have grid lines in gray, then no need to remove the lines. Generally, wise
to remove lines for the Mathsoft digitizer. Just too bad the "Hyper-Digitize"
can't be automated . The matter would be to code the "mouse-left-click".
That was suggested but ignored !
Cheers Mike, enjoy.
Jean
Cheers for the explanation Jean.
Mike
