I am working on a sheet that uses strain compatibility to determine the neutral axis locations of a compression member with given axial forces.
I have attached the part of this sheet that I need help with. I believe I have everything set-up correctly for the constraints and have canceled units within the equations, but now I need to add a solving step. This should be able to work using a function definition with the Find function, but I have not been able to set this up correctly. I am also getting stuck trying to use multiple axial forces (in a vector) and getting an output of the corresponding neutral axis locations.
Any help would be greatly appreciated!
Karl
Sorry, but I don't see any solve block with Find which would fail in your file!?
I did not include it as I believe it has to be part of a function to make this work. I am stuck on how to set up the Find for this situation. I am trying to find "c" given that Pu = Cc + Fs0 + Fs1 ... +Fs7.
Thanks Werner. You rock!
