Error 1722 when installing M020
GrantThompson
I downloaded M020 and installed it successfully on my desktop machine. However, when I attempt to install it on my laptop, I get the message:
"Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor."
Can anyone help with this, please?
Grant
5 REPLIES 5
Which OS?
Richard
Hi, Richard,
Thanks for responding.
I am using Windows XP Professional Version 5.1.
Grant
From the Knowledge base:
# Error �1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected� occurs when installing Mathcad.
Cause: This error generally occurs while trying to upgrade the Mathcad 14.0 from one datecode to another. Moreover is a generic Windows Installer error and is encountered for wide range of windows based products.
Solution: From Add/Remove programs, Un-install Mathcad 14, Mathcad 14 Help and Mathcad 14 Resource center. Latest datecode Mathcad 14.0 can be found here
http://www.ptc.com/support/mathcad_downloads.htm
Note:
Windows Vista users may uninstall using Programs and Features located in Control Panel.
Richard
Hi, Richard,
You are a very helpful person!
Thanks very much for the tip. I'll give it a try.
Cheers,
Grant
It worked!
Thanks again,
Grant
